Kcross47601 13 Posted January 29, 2015 In Sign Blazer, there is a option in the top pull down menu to add a outline to a font or image to add layers. I can't seem to find it in SCALP. In the stock library, there is a red heart that I wanted to outline and after weeding, use only the outline instead of a filled heart for a etching mask. Any help would be appreciated. Kris Share this post Link to post Share on other sites
30-284 86 Posted January 29, 2015 You can always take your heart and then go to object and put a shadow behind it (you can play with different sizes) then draw a new box around it and use the back minus front under path and you will have your outline, then color it to your choice. This is all in SCALP 3, hopefully 4 is similar. Donn Share this post Link to post Share on other sites
GraphxNMore 282 Posted February 23, 2015 Effects>Shadow Layer(conour cut). Then adjust size to what you need. Share this post Link to post Share on other sites
Kcross47601 13 Posted April 30, 2015 Thanks Easy, I just saw this post and have been working in signblazer till now to get this effect. When I figure out how to reduce my pic file size, I plan to post some of the projects I've been on since upgrading. Share this post Link to post Share on other sites
