Mercer57 243 Posted January 27, 2015 I've been wanting to make this upgrade as I want the contour feature and this was less than just the cutter. http://www.ebay.com/itm/300879724537?_trksid=p2060778.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 27, 2015 cool -- working your way up the ladder like so many of us did - remember it is a manual contour - not auto detection but that is a lot more money - I think the titan3 is the cheapest with auto. Share this post Link to post Share on other sites
Mercer57 243 Posted January 27, 2015 10-4 on the manual contour , thats not a big deal unless your a big order shop, I am just a minnow in the Ocean of cutting .I am hoping the lp2 will cut better with less issues than my mh871. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 27, 2015 I am sure it will be a good upgrade! Share this post Link to post Share on other sites
ShowMeCleaning 53 Posted January 27, 2015 I knew nothing coming in. About vinyl cutting and printing. If I had known what I know now. I would have got a contour cutting Machine. 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 27, 2015 I knew nothing coming in. About vinyl cutting and printing. If I had known what I know now. I would have got a contour cutting Machine. With Flexistarter 10 or 11 software, you can turn any cutter into a contour cutting machine.. It does not use a laser. The contour cutting feature is in the software, and uses the blade in the middle of the registration marks..not a laser. then records it in the software. Even if you can find Flexistarter8.6 vs2 It will work. 2 Share this post Link to post Share on other sites
Mercer57 243 Posted January 27, 2015 I have flexi 10 pro, but I wasted a ton of vinyl trying to cut easy things on the mh871, I got an xtra 10% coupon from ebay making the cost of this package 565.98 including shipping, I had to jump on it. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 28, 2015 Save up and in a year or two move up to the Titan 2 or 3 next , Waste goes way down even more 1 Share this post Link to post Share on other sites
Mercer57 243 Posted January 28, 2015 Ditto Showme, live and learn. 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 28, 2015 Yes, expensive software cannot make a value cutter cut any better than it was manufactured to do...But you can still use the Flexisignpro10 for contour cutting, rather than the laser on the LP11, but you cannot use both together,, calibrations are different for offset. I had to pound that in someones head,, with the old Laser Pointer 2.... PCUT with a laser. I went the other way. I put my money on the Graphetc Cutter, and use cheaper Flexistarter8.6.. Great cuts.... 1 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted January 28, 2015 I have a lp2 and it is world's above a mh. I still use the lp2 to contour cut 3G transfers. 1 Share this post Link to post Share on other sites
Kcross47601 13 Posted January 28, 2015 I went from a MH721 to a 50" LP2 and like it now that I started using a Keyspan. The memory on the cutter does not like multiple cut jobs like stensels for mug etching a 40 mug order or a 45" detailed image. If going to be trying a large job, hook to a keyspan. Share this post Link to post Share on other sites
