levy4u 19 Posted January 4, 2015 Graphtec CE6000-60 can perf cut no problem. See my work below, Graphics -> Print -> Cut 2 Share this post Link to post Share on other sites
joker 618 Posted January 4, 2015 So that is contour cutting Share this post Link to post Share on other sites
levy4u 19 Posted January 4, 2015 Ah you're right, forgot to mention I punched those out of the sheet. Thanks for reminding me. See perf cut remains: 1 Share this post Link to post Share on other sites
PointOfExpression 53 Posted January 6, 2015 I love Perf cutting with mine now! 3 Share this post Link to post Share on other sites
jmas 119 Posted January 11, 2015 How'd you do it? I looked into it when I got my cutter and the only instructions I found was for software that I didn't use, and now that I look again I can't find any info on perf cutting. Share this post Link to post Share on other sites
PointOfExpression 53 Posted January 11, 2015 You need to have cutting master 2 plugin for illustrator Share this post Link to post Share on other sites
soldoutcreations 1 Posted January 12, 2015 Perfect cut.... Share this post Link to post Share on other sites
toni98 0 Posted July 18, 2015 Hi. These stickers looks awesome. I will appreciate if you answer some of my questions. What printer did you use to print these stickers? What type of inks were used? Did you laminate the stickers over the print? Thank you in advance. Share this post Link to post Share on other sites
PointOfExpression 53 Posted July 28, 2015 They were used with a pigment ink printer and they were laminated. Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted July 28, 2015 Point what vinyl did you use? Share this post Link to post Share on other sites
PointOfExpression 53 Posted August 20, 2015 I use the Papilio with laminate Share this post Link to post Share on other sites
KYSIGN 233 Posted August 21, 2015 How is your cutting strip? The cutters that are designed to perf cut have a separate blade position over a small channel that prevents blade and cutting strip damage. 1 Share this post Link to post Share on other sites
PointOfExpression 53 Posted August 21, 2015 Cutting strip is just fine. I am using a carrier sheet 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 27, 2015 can the Graphtec CE3000-60 Cutter do countour cutting? There are instructions in the user manual for ARMS, so can only assume there is. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 27, 2015 sounds like a rebranded Graphtec, kinda like what Signwarehouse sells.. As the Vinyl Express line... They have a different driver, and most do not have ARMS Share this post Link to post Share on other sites
acho 3 Posted November 28, 2015 Graphtec CE6000-60 can perf cut no problem. See my work below, Graphics -> Print -> Cut Hi, Can you please explain step by step how did you do that please Beer on me Thanks Share this post Link to post Share on other sites
DoblW 3 Posted June 25, 2016 Cutting strip is just fine. I am using a carrier sheet Oh! That's right, carrier mat sheet, because I'm selling my 1 month old CE6000-60, nothing wrong awesome plotter, even better for Mac OS X user, I just to upgrade to a 42" FC8600-100 to have true perf-cut without using a carrier mat sheet, that is like a 12" x 17", right? Thanks Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 26, 2016 Just so you completely understand, when you perf cut with either of your choices you will be cutting into the cutting strip. Worth the added effort to maintain if you need to do this but it does cause you to go through strips. I don't use this feature and am still running on my original strip 3 years later. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 26, 2016 The FC cutters have a separate groove in front of the cutting strip, for cross cutting,, The FC8600 has a front hole position for the blade holder to fit in..(So it has 2 positions for the blade holder to fit) Front position for blade holder, puts the blade in front of the cutting strip,to the cross cutting groove. So perf cutting is no problem for the cutting strip... Instructional videos on perf cutting with the FC8600 can be found on youtube.com Also we found out from a user in England that the European version of the CE6000-60 had the same set up. So it could perf cut with out damaging the cutting strip. 2 Share this post Link to post Share on other sites
