czwalga 0 Posted December 20, 2014 I have a few basic questions. Is there anyway to get the cutter to stop where you would perform a cross cut after cutting? It goes back to the origin then you have to manually scroll the media through the feed rollers then perform the cross cut once you get it into the correct position. Anyway to speed up 'scrolling' through the media? Moves at a snails pace. Is this the step up function? Share this post Link to post Share on other sites
jarrotto 78 Posted December 20, 2014 Hold the "fast" button and the down arrow key to advance the media quickly. There is also an option in the menu or in cutting master to change how far the media advances after cutting. Information on how to set that should be listed in the manual. Share this post Link to post Share on other sites
pshawny 410 Posted December 20, 2014 I use SignBlazer cutting software. It has an option called "Advance After Job". I have it set at 2.5", so that whatever was cut clears the cutoff area and I can run the slicer across. 1 Share this post Link to post Share on other sites
