TorbenC
Reverse cutting direction
Hi!
I'm gonna cut out some lightning gels.
I have some problems, because there is no backingpaper, to hold on to the gels.
I'm gonna cut out a large circle, with smaller circles inside. But to prevent that everything moves around, I would like to cut out the small circles to start with, and then the outer circle last.
How can I do that?
Just search a cutting mat on here. That should fix all your issues.
Yep find a cutting mat or if you happen to do heat transfers the backing on the Siser products works great as a carrier too as it's sticky but not too stiff.
I can't get a cutting map here. Have to buy it from another country :)
I use the backing paper from some vinyl, but it dosen't stick. (Taping the sides to the gel)
'Just ordered 2  "sticky" cutting mats from local sewing and vac. shop- they are for the ''Brother  Hobby and Craft Cutter"  and are used to stick fabric, paper, and vinyl  to the  re-usable cutting surface. They are Stiff They may be ordered from "Brother Cutting Machine.com and come in various sizes. I plan to tape 2 together for a 24"X24" size.
 Will post again if this works out OK or not
'Just ordered 2  "sticky" cutting mats from local sewing and vac. shop- they are for the ''Brother  Hobby and Craft Cutter"  and are used to stick fabric, paper, and vinyl  to the  re-usable cutting surface. They are stiff!!
