jovial 1 Posted December 10, 2014 I have this image that I was given in different formats but the only programs I have to open it is either Signblazer or Inkscape. With my limited knowledge, I can't get it cleaned up enough to cut. Would there be someone out there with maybe some better software that could vector this and make into an EPS for me? Any help would be greatly appreciated . I also have it in a PVW and DXF format if that helps. The PVW and DXF are exactly what I want, the bitmap is just close.. HondaBlackbird.bmp Share this post Link to post Share on other sites
Wildgoose 4,200 Posted December 10, 2014 I thought Inkscape would open dxf files. Maybe not. Share this post Link to post Share on other sites
skarekrow 1,842 Posted December 10, 2014 VinylMaster will but, the cut file the OP's requesting is verboten here on the forum. Share this post Link to post Share on other sites
jovial 1 Posted December 10, 2014 Yeah that would be great if I owned Vinylmaster. Share this post Link to post Share on other sites
jovial 1 Posted December 10, 2014 I thought Inkscape would open dxf files. Maybe not. It will open it but I dont know how to get it from a DXF to EPS to be able to cut it Share this post Link to post Share on other sites
darcshadow 1,626 Posted December 10, 2014 With Inkscape you simply import the dxf file then do a save as and save it as an eps. Or post up the dxf file and someone on here will probably do it for you. Share this post Link to post Share on other sites
jovial 1 Posted December 10, 2014 I tried to post it on here but got a message that I couldnt. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted December 10, 2014 The forum forbids copyrighted material so you're on your own on this one. (it may have kicked it out due to size too but the above file is definitely protected work) Share this post Link to post Share on other sites
skarekrow 1,842 Posted December 10, 2014 jovial, pm sent. Share this post Link to post Share on other sites
