en187 0 Posted December 9, 2014 I am using Adobe Illustrator CS6 to print directly to my Titan2, everything works great except it will not cut retangles! If I draw a rectangle filled black or any color without a stroke it will simply not cut with the image.. If I add strokes it will cut both inside and outside of the stroke line. My question is why does it cut every other shape that is simply filled with black but not rectangles. It is a pain in the butt! Is there a setting or something I have to do? Trying to print text with the IMPACT font and does not cut any of the I's... Share this post Link to post Share on other sites
Boom 7 Posted December 9, 2014 Maybe you need to expand it? What cutter program are you using? I usually expand everything including text. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 9, 2014 boom - the titan will cut directly from illy and corel - kind of like you can do with cutmaster but you only install the drivers as I recall - no other software Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 9, 2014 Your cutter is a rebranded SAGA.....I was looking at the Saga site,, It lists 2 plugins for Corel, Illustrator Autocad etc.. as "cutting" drivers..Seems difference is where Origin ends....(ADVANCE AFTER CUT OR NOT) Then it also lists one plugin as a printer driver. 32 and 64 bit.. Maybe that is the difference.?? So are you cutting or printing? http://www.sagacnc.us/content/6-downloads Share this post Link to post Share on other sites
en187 0 Posted December 9, 2014 I am cutting, like I said everything else cuts fine, everything but any rectangle within the image, I convert text to outlines before printing also Share this post Link to post Share on other sites
en187 0 Posted December 9, 2014 Maybe you need to expand it? What cutter program are you using?I usually expand everything including text. I cut directly from illustrator Share this post Link to post Share on other sites
