racert25 2 Posted December 7, 2014 I can not get my new cutter to start at the edge of the vinyl. no matter where i load the vinyl it starts in the same spot and will not allow me to toggle right. When i push the carrage i get a y axis alarm. Any ideas? Share this post Link to post Share on other sites
pshawny 410 Posted December 7, 2014 Place the pinch rollers in the up position, then manually move the cutting head to the right. Set the origin. Also, the cutter will only cut between the pinch rollers unless you adjust a setting in the menu. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 7, 2014 are you trying to go past the point the pressure roller sits? the ce6000 by default senses the edges and won't go past the pressure roller unless you turn off that sensor somewhere in the menu Share this post Link to post Share on other sites
mr300s 1,272 Posted December 7, 2014 You also need to have it set to # 2 when it starts after you load the vinyl hit cond on the keyboard and make sure it show 2 if not use the arrows to change it to 2 Share this post Link to post Share on other sites
racert25 2 Posted December 7, 2014 Ok thanks that makes sense. I will look for these settings. Thanks Share this post Link to post Share on other sites
