krolyat
LaserPoint I 24" stand for a SC 25"
Does anyone know if I can use my old LaserPoint I stand on the new SC 25"?
Thank you!
worse case scenario if it doesn't fit is add a board to the top of the stand and screw the cutter to that - just make sure to run a ground wire as the stand would be insulated from the grounded cutter and you would run into the same problem the mh people have with static
You ain't lying about the static. I just ran a ground after the static got so bad the siser was stuck down to the cutter on my q75. Wasn't expecting that and it is on a stand modified with a board across the top.
