harleytuner 37 Posted November 23, 2014 OK, so I ordered a heat press so I can make shirts for my shop. My logo is 2 color. 1'st? Do I apply each layer to the shirts separate or can I put them together then apply like I would a decal? 2nd? Is there a special application tape I use after weeding? Or is the same medium tack stuff I use for vinyl sufficient? 3rd? Where is the best place to buy the parchment paper? lol Hobby type shop? Here's my logo, any advice on the best technique to get this on a shirt would be greatly appreciated. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted November 23, 2014 NO app tape needed. The carrier it comes on acts as the tape. Best to last one color and press for 3-5 seconds then peel the carrier and apply the second color pressing for the full time. Parchment paper can be had at any grocery store but I get mine from Dollar Tree stores when I happen to get to town. As fas advice just remember anything done in HTV has to be cut in reverse. 3 Share this post Link to post Share on other sites
mb20music 760 Posted November 23, 2014 I suggest purchasing a Teflon Sheet to use rather than the Parchment Paper. One Teflon Sheet will last for hundreds of presses... http://www.uscutter.com/Teflon-Sheets-for-Heat-Presses 1 Share this post Link to post Share on other sites
harleytuner 37 Posted November 23, 2014 Thanks so much for the info, i'll order the teflon sheets and pick up some parchment paper as well, so I have something to use while i'm waiting for the teflon. I really appreciate the info. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted November 23, 2014 Um, I get hundreds of presses out of my cheap parchment paper too. Just be careful with it. I use a teflon to give some HTV a little bit of texture look but still press primarily with the parchment paper. Lighter and less likely to accidentally drag my design out of alignment and you can see through it for that last second view before the press. The Teflon can get wrinkled over time too and these will show up in some HTV work. Share this post Link to post Share on other sites
