Josh623 0 Posted October 29, 2014 On the site here it says one of the features is: "Import various file formats, including SVG, PDF, EPS, AI, WPC" So why won't it let me trace an .eps file? I did a little bit of reading... looks like I will have to convert the eps file in inkscape to svg or something... any suggestions? Share this post Link to post Share on other sites
signyouup 178 Posted October 29, 2014 You don't have to trace an EPS, it's already a vector file. 1 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 29, 2014 Eps does NOT mean for certain it's a vector file. It will trace jpg and a few other true raster filetypes. 2 Share this post Link to post Share on other sites
Josh623 0 Posted October 29, 2014 So if I have an image like this and just want to pull out one shade of gray and print, what are your suggestions? https://drive.google.com/file/d/0B8rkweHq-CgmNTliZEZ4aEswRHM/view?usp=sharing Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 29, 2014 That is a vector file... Share this post Link to post Share on other sites
Monkey 252 Posted October 29, 2014 Its hit and miss on what files SCALP will open. I have a ton of EPS files it wont open and a ton it will. Now I just do all my work in CorelDraw and use the plug in to send directly to scalp, then just cut. 2 Share this post Link to post Share on other sites
Josh623 0 Posted October 29, 2014 Monkey, that's an interesting point you made. I have Adobe Illustrator... i think I will post in that area to figure out how to do this with AI so I don't have to buy another $500 program! Where did you get the plug in? do they make one for AI? Thanks for the input guys. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 29, 2014 Plug in info is in the UScutter support http://www.uscuttersupport.com/kbpage.html#Vinyl_Cutting_Software_Installation_Use 1 Share this post Link to post Share on other sites
Lil' Angel 0 Posted March 30, 2021 I can't get Corel to do this at all and I have sure cut pro 3 Share this post Link to post Share on other sites
haumana 1,220 Posted March 30, 2021 2 minutes ago, Lil' Angel said: I can't get Corel to do this at all and I have sure cut pro 3 What are you trying to do with Corel? Share this post Link to post Share on other sites
Lil' Angel 0 Posted March 31, 2021 15 hours ago, haumana said: What are you trying to do with Corel? So I have this image I bought and this is not the only one, so I left the person good Feedback but told them unfortunately, I can't use most of their images so they asked me to upload one and they would try and help me. So I got a message back saying: I read this thread: forum.uscutter.com/index.php?/topic/46877-sure-cuts-a-lot-pro-not-workin... and he used CorelDraw and use the plug in to send directly to scalp, then just cut.Here is the link of plug-in: www.uscuttersupport.com/kbpage.html#Vinyl_Cutting_Software_Installation_Use . But I've not gotten it to work at all. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 31, 2021 1 hour ago, Lil' Angel said: So I have this image I bought and this is not the only one, so I left the person good Feedback but told them unfortunately, I can't use most of their images so they asked me to upload one and they would try and help me. So I got a message back saying: I read this thread: forum.uscutter.com/index.php?/topic/46877-sure-cuts-a-lot-pro-not-workin... and he used CorelDraw and use the plug in to send directly to scalp, then just cut.Here is the link of plug-in: www.uscuttersupport.com/kbpage.html#Vinyl_Cutting_Software_Installation_Use . But I've not gotten it to work at all. What plotter do you own? Share this post Link to post Share on other sites
Lil' Angel 0 Posted April 1, 2021 On 3/31/2021 at 10:12 AM, Dakotagrafx said: What plotter do you own? I own 2 One I use now is MH721-MK2, which use's Sure cuts A Lot 3 Pro. The other Is a PCut630 Which I've not used in awhile, I can use Signblazer with that one, but not the one I'm using now. Share this post Link to post Share on other sites
darcshadow 1,626 Posted April 1, 2021 Signblazer works with the MH, that was the default program for the MH up until about 5 or 6 years ago. 1 Share this post Link to post Share on other sites
haumana 1,220 Posted April 2, 2021 Is there a way for you to verify with SCALP that the plug-in actually works for your version of CorelDraw? Share this post Link to post Share on other sites
Lil' Angel 0 Posted April 2, 2021 18 hours ago, darcshadow said: Signblazer works with the MH, that was the default program for the MH up until about 5 or 6 years ago. Can you tell me how maybe? Share this post Link to post Share on other sites
Lil' Angel 0 Posted April 2, 2021 14 hours ago, haumana said: Is there a way for you to verify with SCALP that the plug-in actually works for your version of CorelDraw? I can install the plug in and it their, but when I sent to SCALP, I get an error. I forget that Error, but it never sends it Share this post Link to post Share on other sites
haumana 1,220 Posted April 2, 2021 Installing it does not necessarily means that itʻs compatible. Have you checked with SCALP to see if your operating system, SCALP version, and CorelDraw version are compatible? What kind of error are you getting, can you post a screen shot of the error? Share this post Link to post Share on other sites
kainth.c.s 53 Posted April 3, 2021 On 10/30/2014 at 8:28 AM, Josh623 said: So if I have an image like this and just want to pull out one shade of gray and print, what are your suggestions? https://drive.google.com/file/d/0B8rkweHq-CgmNTliZEZ4aEswRHM/view?usp=sharing Have a look at this. It has all four layers separated. Is this something you are intending to do? Open this file (either using open and import command) and have a look By the way Mzkeeter said right, it is a vector file Digi-cam [Converted].pdf Share this post Link to post Share on other sites
haumana 1,220 Posted April 3, 2021 23 minutes ago, kainth.c.s said: Have a look at this. It has all four layers separated. Is this something you are intending to do? Open this file (either using open and import command) and have a look By the way Mzkeeter said right, it is a vector file Digi-cam [Converted].pdf I doubt youʻll get a response from the OP (Josh623), as his post was done in 2014. Share this post Link to post Share on other sites
kainth.c.s 53 Posted April 3, 2021 No problem buddy, I forgot to check the date Share this post Link to post Share on other sites
Lil' Angel 0 Posted April 14, 2021 On 4/2/2021 at 6:53 PM, haumana said: Installing it does not necessarily means that itʻs compatible. Have you checked with SCALP to see if your operating system, SCALP version, and CorelDraw version are compatible? What kind of error are you getting, can you post a screen shot of the error? @haumanaHere is the Error I get. Sorry been busy. Share this post Link to post Share on other sites
haumana 1,220 Posted April 14, 2021 Have you reached out to SCALP, and what was their response? What version of CD are you using? Share this post Link to post Share on other sites
Lil' Angel 0 Posted April 15, 2021 22 hours ago, haumana said: Have you reached out to SCALP, and what was their response? What version of CD are you using? No I haven't, I was told by someone that it would help me. I have ver: Sure Cuts A Lot 3 Pro, Coreldraw ver: 2021. Scalp 3 I think. Share this post Link to post Share on other sites
darcshadow 1,626 Posted April 15, 2021 I googled that error message and found an old thread where it was suggested it was a problem with the plugin not compatible with Coreldraw. That may be the case here, your CorelDraw is too new. Contacting SCALP would most likely be your best bet. 2 Share this post Link to post Share on other sites
