Monkey 252 Posted October 28, 2014 I see a lot of people talking about the value cutters not being able to cut small successfully. With a little tuning, I think my SC does a pretty good job. DOing a order of shirts with HTV and 3 of the shirts are XS child. So of course had to resize design for them. You cant read the ruler well but the design is 8" wide. The font in the corner is for the front pocket area so not included on design size. Those "e"s in the center measure just barely over 1/8" tall. I shake like a dog crapping a peach seed also due to nerve damage, so weeding can be a chore normally. So this is just to show you cant count the value cutters out. At least the SC. No its not a Graphtec and yes Im saving for one, but it does the job in the meantime. 8 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 28, 2014 My LP2 will do most of what my graphtec will it just takes more fine tuning and it cuts slower. It was also $1100 cheaper than a ce6000 Share this post Link to post Share on other sites
Monkey 252 Posted October 28, 2014 Yes slow is key. 3 Share this post Link to post Share on other sites
security802 686 Posted October 28, 2014 Yes slow is key. The fastest I run is 200 on mine. Reflective I run at 100 Share this post Link to post Share on other sites
Monkey 252 Posted October 28, 2014 Yeah I used to only run at 100 being overly anal about things. But bumped it up to 200 and thats where it stays unless super thin detail then drop back down. Usually fine scroll work. Share this post Link to post Share on other sites
JonnnScott 58 Posted October 28, 2014 This is awesome, Im ordering my SC cutter right now and this makes me happy knowing if I wanted to I could cut this small. Share this post Link to post Share on other sites
joker 618 Posted October 29, 2014 JonnScott it takes some fine tuning.. Monkey mine does the same thing.. 1 Share this post Link to post Share on other sites
xpaperman 719 Posted October 29, 2014 I get that small with my SC too! However, I run mine at 400 most of the time and drop down to 200 for that small stuff. When cutting bigger things, don't be afraid to bump up that speed.... no need sitting there longer than you have to. Share this post Link to post Share on other sites
ShowMeCleaning 53 Posted October 29, 2014 SC works great for smaller letters. But less than 1/8" for get for me. That's me. Not everyone. I just wish may SC had a laser on it for contour cutting. Cause I can't figure out how to contour cutting on my SC. Anyone with any guidance on how to do it. Please let me know. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 29, 2014 I won't normally cut 1/8" anyways there is not enough surface area to keep it attached. If using Flexi starter you can contour cut because you use your blade for alignment at the reg. marks. Share this post Link to post Share on other sites
vezman71 4 Posted October 30, 2014 I get that small with my SC too! However, I run mine at 400 most of the time and drop down to 200 for that small stuff. When cutting bigger things, don't be afraid to bump up that speed.... no need sitting there longer than you have to. That's me, mine pretty much stays at 400, then if I'm cutting something a little more detailed/small I bump it down. I've even turned it up to run 500 on large 6.5" numbers I was doing in HTV for some jerseys. Share this post Link to post Share on other sites
