dkipp 14 Posted October 25, 2014 Hi Everyone: So I'm trying to cut with my SC that I just received and I'm running into a slight problem that I beleive is operator error. I have attached the original and the result, If you can help point me in the right direction I'd appreciate it. I'm using a 45 blade that appears to be adjusted properley per the instructions and I'm using 300 mm speed and 6g pressure, althought changing these settiings didn't seem to make a difference. Again, I'm sure it's something I'm not doing correctly. Its seems like the blade head is catching the vinyl it's already cut, causing it to peal back. I've used both 631 and 651 and really no change. Also, the cutter is making 3 passes on the cut and I'm not sure if that's normal or the cause. Thanks in advance Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 25, 2014 Your wrote " I'm using a 45 blade that appears to be adjusted properley per the instructions" Who's instructions? This is how to set your blade correctly to get you started. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. 1 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 25, 2014 3 passes is not normal. Either a bad file or multi cut is turned on. If you post the file somebody will take a look at it. Share this post Link to post Share on other sites
busterbay 326 Posted October 25, 2014 To much blade my friend. Check the settings in your program I agree with Jaybird you either have a bad file or have it set to cut 3 times. Share this post Link to post Share on other sites
dwp99 283 Posted October 25, 2014 I've heard that the instructions say to set the blade with a stick out the thickness of a credit card. Well that would be good if you are cutting through credit cards. Do what MZ Skeeter says and you'll be set to go. Also check what Jay and busterbay mention about having the software set to 3 passes. Where did you get the file, I did a search on Google for "Got Milk Mastiff Decal" and came up with a couple. Be careful they've been copyrighted. Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted October 25, 2014 Looks like a MH Cut that Share this post Link to post Share on other sites
dkipp 14 Posted October 25, 2014 Thanks I'll give those things a try, when my house wakes up..lol To help clarify Instructions I got from this site on how to adjust the blade..http://www.uscuttersupport.com/downloads/Support_PDF/CutterSetup/Blade_Guide.pdf The multi cut function is off, so perhaps it's a bad image. I've attached the jpeg I'm tracing in sure cuts alot The image I was just practicing with and have no intention of using, I'm actually tracing my own and doing something similar.. Thanks again Share this post Link to post Share on other sites
security802 686 Posted October 25, 2014 Thanks I'll give those things a try, when my house wakes up..lol To help clarify Instructions I got from this site on how to adjust the blade..http://www.uscuttersupport.com/downloads/Support_PDF/CutterSetup/Blade_Guide.pdf The multi cut function is off, so perhaps it's a bad image. I've attached the jpeg I'm tracing in sure cuts alot The image I was just practicing with and have no intention of using, I'm actually tracing my own and doing something similar.. Thanks again Make sure you are tracing in monochrome and not color mode in scalp and readjust the blade per MZ Skeeter's instructions Share this post Link to post Share on other sites
RickS 39 Posted October 25, 2014 this is typical of some designs, there are possibly three layers in that file, I use Flexi so I can't comment on your software, but see if there are several layers. If your software has a wireframe view use that and then click on the parts and drag to the side to see the layers, then delete the unneccessary layers. Share this post Link to post Share on other sites
dkipp 14 Posted October 25, 2014 Hi Guys: Well like everyone said, it's the image, I tried some different images and lettering and it worked perfect. Blade depth was spot on. Trial and error will be my story for a while.. I'll play with that wireframe view and see how that works for this particular image.. Thanks again Share this post Link to post Share on other sites
