MattS 0 Posted April 7, 2008 I know this has been brought up a few times and I think I have read them all, but why is my graphic disappearing when I edit a node. It doesn't always do this, but enough that is really gets to ya. Especially when you are trying to hurry up and get something cut. I have tried refresh, updates, and even the secret update that was posted a while back that wasn't released to the public yet. It seemed to work better, but know its doing it often again. It doesn't matter if is a cuttable eps files, a combined file, a welded files, or a sb files. They all vanish with out a trace. Sometime when I zoom in and out, it will partially show back up, but I can't select it or anything. I usually have to undo back to a workable graphic or sometimes I have to start from scratch. BTW - I have SBE Thanks for any suggestions. Matt Share this post Link to post Share on other sites
Bruce SignBlazer Support 0 Posted April 7, 2008 Try pressing the "F7" key to zoom to the drawing objects or "F8" to zoom to the workspace. This may show you where the objects are. Share this post Link to post Share on other sites
Jay2703 704 Posted April 7, 2008 Can you post one of the graphics that is doing this? Share this post Link to post Share on other sites
ff-extreme 6 Posted April 7, 2008 I sometimes have the same issue so I dont think its going to be a design issue.....but then again what the helx do I know! Share this post Link to post Share on other sites
firemalt 10 Posted April 7, 2008 I got that every once in a while... usually after I try to do a total weld, but it's also happened when/after node editing. Share this post Link to post Share on other sites
MattS 0 Posted April 7, 2008 I tried the F7 & F8 and it didn't do anything. Here is the SB file if someone wants to try it. LA Ducks.SBD LA Ducks.SBD Share this post Link to post Share on other sites
Jay2703 704 Posted April 8, 2008 I couldn't get it to do it. I tried importing .eps files, .jpg's and .gif's to your design. I vectorized them and nothing. It works OK for me. Share this post Link to post Share on other sites
Guest fivestar Posted April 8, 2008 Are you clicking in between nodes, on the line then hitting delete? That will cause you to delete the whole image. Share this post Link to post Share on other sites
MattS 0 Posted April 9, 2008 Are you clicking in between nodes, on the line then hitting delete? That will cause you to delete the whole image. Nope, just takes moving one node and its gone. Share this post Link to post Share on other sites
MattS 0 Posted April 9, 2008 Here is a video of what it is doing to me. http://s210.photobucket.com/albums/bb262/MSCustomCalls/?action=view¤t=sb.flv Share this post Link to post Share on other sites
MattS 0 Posted April 19, 2008 I finally got a chance to test that one again. I found that I had full render turned on. I turned it off and everything seems to be working now. Thanks for the help. Matt Share this post Link to post Share on other sites
