THEJTINS 29 Posted October 11, 2014 I need to add font to the bottom of a circle in scalp3. but it always types with the bottom of the letter touching the path/circle. Is htere a way ti invert text when typing so that the letters in essence would hang from the bottom of the circle from their tops rather than their bottoms? Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 11, 2014 What does the HELP menu in ScalPro say about this function? In SignBlazer, the function of Text Follow Arc (TEXT menu) provides for "Above/Below" and "Clockwise/Counterclockwise" Share this post Link to post Share on other sites
30-284 86 Posted October 12, 2014 Try the offset in the text properties box. Donn Share this post Link to post Share on other sites
THEJTINS 29 Posted October 12, 2014 I figured it out. What a pain in the A$$ SCALP3 can be for some of the simplest things. Share this post Link to post Share on other sites
Cal 393 Posted October 12, 2014 Please post up the answer for us... Thanks, Cal Share this post Link to post Share on other sites
THEJTINS 29 Posted October 13, 2014 select the path you want to type on. right click and select transform then rotate. it will have your trxt move to the underside rather than the top. then you can right click and flip it. it'll take some tinkering with and probably a "how'd I do that" moment but it'll happen. 1 Share this post Link to post Share on other sites
painperdu 3 Posted October 15, 2014 I've found that SCALP screws up alignment of letters when text on path is used. Notice how some of the letters in the above image don't align up correctly on the bottom. Inkscape handles text on path much better. Share this post Link to post Share on other sites
skarekrow 1,842 Posted October 15, 2014 Yeah... what is the deal with that "d" ? Share this post Link to post Share on other sites
LPWash 75 Posted October 16, 2014 That is one thing I wish it would do better. You can rotate the letters as a group or individually if you need to. Share this post Link to post Share on other sites
cc23rdb 0 Posted October 17, 2014 I'm new to this. But I wanted to do a simple logo with a low curve arch for the first line for the company name. Then straight across for the phone number. The only arch I have is a half circle. After hours with SCALP and ink(something) I gave up.. I went into my embroidery software, typed the company name, arched it perfectly, print screened, and pasted it into my photo program. I saved the pic, then traced it into SCALP. Best idea I've had. Sounds like a lot, but can do a simple logo in under 5 minutes with that perfect arch. A simple embroidery digitizing program (that does different skewing, of course) could help. I use a higher priced program, but there's some that you can get free, or download a free trial. I'll see if I can post a photo of a decal with an arch. Share this post Link to post Share on other sites
cc23rdb 0 Posted October 17, 2014 Its not a big arch. But I guess its what I'm used to for company logos and hat designs, and shirts. And I sure couldn't get the result from anything I tried. Share this post Link to post Share on other sites
