98crewcab 21 Posted October 2, 2014 Part of our logo/design involves two different orange colors. But for ease of layout (and not having to purchase another $60 roll just for the couple small spots) I was considering "spray painting" over the section to darken the orange hue....is there a spray paint that I should stay away from? do they react to the enamels negatively? I am going to to some testing today, but as far as long term....would it be a bad idea? thank you tons in advance:) Matt Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 2, 2014 some people used to play with krylon fusion to make a fading pattern on vinyl but not sure on longevity - it kind of defeats the purpose of the color going all the way thru for durability (of using solid color cut vinyl) 1 Share this post Link to post Share on other sites
98crewcab 21 Posted October 2, 2014 that makes sense, works on plastic, pvc, why not vinyl.....and only needing enough of a change to offset the two parts. So maybe the slight overspray just to darken it up a bit..... thank you for your input. I think my biggest concern would be the paint curling up vinyl, or causing another reaction to the vinyl, and that would probably happen right away, not so much once its been applied to the vehicle....lol Share this post Link to post Share on other sites
FrznFire07 217 Posted October 2, 2014 we actually do this quite often, we have a company in town that wanted a silver metallic with a blue fade on their trucks and for a long time we used krylon spray paint on Oracal Silver 951 to achieve the look. They still look good 7 years later. 1 Share this post Link to post Share on other sites
edge 67 Posted October 2, 2014 When painting the vinyl, is it done prior to application and are there any worries of some paint lifting from application tape removal? Share this post Link to post Share on other sites
98crewcab 21 Posted October 2, 2014 perfect, thanks Frozen!! Share this post Link to post Share on other sites
Moody Blue 505 Posted October 2, 2014 I've painted vinyl using automotive paint. I painted it and then cut it with the plotter and it worked great...just needs to cure for a few hours before you start cutting. 1 Share this post Link to post Share on other sites
knucklehead 530 Posted October 2, 2014 Used to do it regularly. Used automotive paints, solvent and waterbased. 1 Share this post Link to post Share on other sites
Jburns 239 Posted October 3, 2014 I have used Patra paints on oracal 751, 651 placed on lexan- i beleive they are laquers. no problems after years of use. 1 Share this post Link to post Share on other sites
