sonix 0 Posted September 30, 2014 Hello, i have printed 100 pieces of sticker with 4 registration marks. When i wanted to perform contour cut from flexisign, it started cut correctly, but after 45 sucessfully contour cutted stickers the contour started be shifted about 4mm under the stickers (photo in attachment). Does somebody had problem with this? Is there some adjust or alignment in graphtec or in flexi? I donť know what to look for. This is my first contour cut using CE5000-120. How to solve this ? Tom Share this post Link to post Share on other sites
Englishman 0 Posted November 22, 2014 Are you using CM2 or 3 ? In 3 you can add multiple reg marks so it effectively breaks one bib job in to a bunch of small ones and keeps things more acurate. We switched from CS2 to 3 and add multi reg marks and it's helped a TON. Share this post Link to post Share on other sites
