101LEDs
T shirt shaped Sign with template
  1. Download the file at the bottom.
  2. Open and use the draw function to trace the shirt outline on your paper media or cut out of vinyl if desired. (skip 3 if vinyl is used)
  3. Tape the template to your material and use a sharp knife to cut through the paper to leave the outline.
  4. Slowly cut the outline free, watch for the blade catching flutes.
  5. Cut the trim pieces out of vinyl, 2x if doing a double sided sign.
  6. Design/cut your text. 12" wide worked good. Everything is sized for 18x24 coroplast.
  7. Apply vinyl like a normal sign.
Long side flutes would be best but you can use either. If you change the size don't forget to change the trim sizes too.
Shirt sign Template.svg
post-87856-0-07652900-1411609441_thumb.j
  • Like 4
