thestartingline
Copam cp2500 driver issues Prolific Usb to serial u232-p9 (black)
Im  having issues getting my copam to connect to my computer. I had it working before on this computer, but had to wipe my hardrive. I had a link to the old driver (the one that worked), but its no longer available. Im using the prolific black usb to serial controller with sign cut x2. The drivers off the cd dont work. I have also tried downloading some of the new drivers without any luck. The most i can get the cutter to do is start scrolling my vinyl and not cutting the file. Where can i get drivers for the black prolific controller?
Thanks
It could be installing the incorrect driver, in which case you would need to force the correct driver in. The black cable should be the USB 2.0, not the Prolific like Marcus mentioned. If you need assistance forcing the correct driver in, send me an email with your phone number: kenimes@uscutter.com
