JGF 0 Posted August 27, 2014 I'm trying with no luck to straighten the lines and curve the curves out of this old logo, but am getting maybe 1 letter done within two hours. Is there an easier way. For example when I attempt to work on the letter "R" the node shoots across in one direction and if I try to drag it back to where it needs to be, it goes in another direction. Please any help anyone can give me would be much appreciated. I've also tried to attach a file of the logo, but it says "This file is too big to upload" Share this post Link to post Share on other sites
joker 618 Posted August 28, 2014 Gonna try and help out here.. First - resize your image if you can. Second- when you node edit in signblazer use your zoom button and zoom al the way in. Third- delete some nodes being that you do not need all of them.. The zooming in will help you because then you can see how far you move the node When you click the node hold the mouse button down and then move it where you want it,, Hope this helps Share this post Link to post Share on other sites
JGF 0 Posted August 28, 2014 Thanks for all your help. I'll give it another shot in the a.m. Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 28, 2014 Always keep in mind that the "nudge" factor can be adjusted, so that it either is a very minor position change for each nudge movement, or can be increased to jump in larger increments. (NOTE: this was my 3000th posting !!!) 3 Share this post Link to post Share on other sites
