KRStudios 1 Posted August 19, 2014 I have a Graphtec CE5000-120 and after someone (who shall remain nameless) used it, destroyed the cutting strip, and messed with settings, it is no longer closing the cuts on letters and shapes. I have replaced the teflon cutting strip, I have changed out the blade and the blade holder, I have checked the blade and holder for dirt/vinyl reminants, etc; I have put a drop of oil into the holder, I have tried everything that I have seen suggested for people having a similar problem and nothing seems to be working. I am open to other suggestions! Thanks!! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 19, 2014 what is the blade offset set at? It should be Zero 0.... Also have you tried the factory reset?? Turn power off, turn cutter back on while holding down the UP arrow... Also use overcut in your cutting software... Is the carriage head snug and tight.. Carriage arm not broken? White carriage wheels, down firmly in track? ,, Make sure the grit rollers on the bottom are tight, as well as the pinch rollers on top,,, Never be pulling directly from a roll of vinyl, always have slack vinyl to pull from.. prefeed your vinyl.. Share this post Link to post Share on other sites
KRStudios 1 Posted August 19, 2014 I have tried restoring factory defaults. There are two different offset settings- offset angle and offset force. which one should be zero? Share this post Link to post Share on other sites
KRStudios 1 Posted August 19, 2014 what is the blade offset set at? It should be Zero 0.... Also have you tried the factory reset?? Turn power off, turn cutter back on while holding down the UP arrow... Also use overcut in your cutting software... Is the carriage head snug and tight.. Carriage arm not broken? White carriage wheels, down firmly in track? ,, Make sure the grit rollers on the bottom are tight, as well as the pinch rollers on top,,, Never be pulling directly from a roll of vinyl, always have slack vinyl to pull from.. prefeed your vinyl.. I found the other place to change offset and realized my plotter was set for a blade different than what i am using. THANKS! 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 19, 2014 I have tried restoring factory defaults. There are two different offset settings- offset angle and offset force. which one should be zero? Offset force zero What cutting software are you using? Share this post Link to post Share on other sites
djque 246 Posted August 19, 2014 I have tried restoring factory defaults. There are two different offset settings- offset angle and offset force. which one should be zero? offset on the cutting screen should be 0 the one under advance is the on you change for the type of blade your using and what the it says on the setting. I use cleancut 60* and they say use .45 for offset angle (In advance) Condition: drop down Offset 0 speed acceleration cut force Advance: drop down: step pass offset angle (45) cleancut 60*) this is what most over look init. Force speed Share this post Link to post Share on other sites
