mac6986
White ink - Roland
I know this is a real long shot, as white ink is relatively new, but does anyone else here have a Roland printer with white ink and have actually printed jobs with it?
I need to pick someones brain with a problem I'm having with overprinting white.
cutme (or stickermonster - can't remember what he goes by on each forum)  has one but he hasn't been on the forum for over a year I think
I had a couple print shops do some test prints with white ink.  One was on a Roland, and the other a Mimaki.  Neither one had any opacity.  I had them print on clear vinyl to produce decals.  As soon as you put the decal on a dark surface or helmet you can't tell the white was even there.  Also, the white didn't really improve the opacity of the other colors either when used as a base print.  A blue decal on a yellow helmet turned green.  You have to go thermal to print white on clear, if that's what you're doing.  You need a Gerber edge, or Summa DC4.
I have the New VS-300i, I was able to get the desired opacity by jacking up the ink limit in the media profile, and over-printing twice. Customer was happy with the sample, I was awarded the job.
The problem they are going to run into is the specialty vinyl I was required to use will deteriorate before the print will. I tried to explain, but I guess they know better.
I've only been printing and cutting vinyl every day of my life for the past 8 years, what do I know, lol :rolleyes:
