peterbeedham
Cutter doing 4 0r 5 test cuts after pressing cut button
Hi Everyone
As you can see i'm new here, but have been sign writing with vinyl for a year or so   I have a MH721 and use signblazer.
If possible i would like some advice please.
When i go to cut in signblazer, the cutter automatically displays test and  tries to move but can't and that is it. it does light up and make a noise , so i know the cutter has power, if i press the test button it does do a star / test cut..
Help would be appreciated
Peter
There is a trial of sure cuts a lot pro I think on uscutter downloads. You can try that to eliminate it being software related.
 Not the software cause this problem. maybe the motherboard has something wrong and need to be replaced. I suggestion you contact the local technical support for help.^_^
