iamandy
Safely remove vinyl from Van
Magic eraser will also remove the adhesive --- ancient Chinese secret
Park it in the Sun use plastic razor blades to lift the edge and pull. If you have nothing better Rubbing Alcohol will take the adhesive residue off.
Rapid Remover lives up to it's name. Just be careful using it on some plastics.
Heat gun on low setting works the best.   Work the edges a little longer.  Not long enough and it won't come off.  Too long and it gums up too much where it just gets gummy and breaks off.   Once you get the timing down, it will pull the vinyl AND the adhesive off.  It took us a 16' box truck to figure out the best method.  Tried everything on both sides and it wasn't until half way on the final backside where I figured it out and then we were pulling off two foot long sections at a clip, adhesive included.  Good luck.
