MZ SKEETER 4,709 Posted June 25, 2014 Corel is not cutting software. It is a design software.. There are no drivers. Possibly try Signblazer, It is a free design and cutting software. It has not been updated for years, as owner passed away. But for FREE, it will work. But you will have to save your design files in an older version 8 eps format. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 25, 2014 this is the only way I have seen it done from Corel posted by another member Posted 09 May 2011 - 08:36 AM How to cut direct from Illustrator & CORELHi GuysFirst of all you must get a NULL MODEM CABLE to go from computer to (plotter) cutter.Make sure it’s a NULL MODEM CABLE and not just a PRINTER CABLE.Null Modem serial cables allows two DTE or DCE devices to communicate with no conflict in data transmissionThen convert your line weight to the thinnest (the one with 2 ARROWS).Set all lines at Wire frame.Export as a .DXF file.Send your .DXF file to your Printer.Set your printer preference to your plotter cutter at PRINT.REMEMBER YOU MUST CUT FROM A .DXF file.This works for me and I hope it works for you. Thank You,Bob Bigart Share this post Link to post Share on other sites
