mcrocker 0 Posted June 18, 2014 Hi can anyone help with this? I'm trying to set the home origin like thye say in the tutorial video, I set it when it was right over on the left side, if I press reset then it moves back and forth and stays right where I put it. But when it starts cutting it shifts to almost a foot in from the side and that's where it starts cutting. I'm doing blast mask and I have the pieces cut say 15 x 15 for the 12 x 12 rock it will be blasted on, so when it shifts like this it doesn't have enough room to do the side of the stencil. Anyone have any suggestions? It's for a Titan 2 by the way, forgot to put that in there Thanks Share this post Link to post Share on other sites
Jay2703 704 Posted June 18, 2014 What software are you using? Share this post Link to post Share on other sites
mcrocker 0 Posted June 18, 2014 I'm using Sure Cuts A Lot Share this post Link to post Share on other sites
Jay2703 704 Posted June 18, 2014 I don't use SCAL but is there an option in the cut setup to move what is cut to the origin of the cutter. Share this post Link to post Share on other sites
mcrocker 0 Posted June 18, 2014 I don't think it's a SCAL problem, I think it's something I'm doing while setting the home origin on the cutter. ON the video tutorial, it shows the numbers changing for X and Y on the screen when you set the home origin but mine both stay at 0 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 18, 2014 PM sent, See if that helps you. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted June 18, 2014 Make sure scalp is set to origin and not wysiwyg. 1 Share this post Link to post Share on other sites
JessXEmoji 46 Posted June 18, 2014 I never had to set anything on my sc cutter just started cutting. Maybe i should have set something.. Share this post Link to post Share on other sites
TT57 135 Posted June 19, 2014 Jesse, i don't set my origin either on my SC with my SCALP. I just put everything at the bottom right and start cutting. Also making sure that wysiwyg is selected. I have however set it to origin to see if it goes there and yes it does but i find it easier to just cut from bottom right. I use origin if i place something on a mat to cut and place it there for that. Share this post Link to post Share on other sites
starsjoy23@hotmail.com 0 Posted July 8, 2014 I'm new also. I have a US Cutter 871 and use SC Pro cuts also. I'm having the same issue with the cutter shooting out about a foot of vinyl before it starts cutting. Do I need to set my X and Y to anything or just hit reset and origin? One person says Origin and one says Wysiwyg. Help Share this post Link to post Share on other sites
slice&dice 2,450 Posted July 8, 2014 Think of it this way ---- WhatYouSeeIsWhatYouGet will NOT produce a cut that begins wherever the plot path in the design begins, regardless of the dimensions of the mat. In other words, if you have a mat of 36" x 24" and a 2" x 2" design is placed somewhere in the middle, the cutter will INDENT & MOVE to reach the start point of that small design. That is usually a waste of vinyl. The ORIGIN setting causes the cutter to immediately cut the design plot, and IGNORE the overall dimensions of the mat. It will cut ONLY 2" x 2" right from the corner of the vinyl (or wherever the Origin point is manually set by using the cutter keypad). If I remember correctly, the SC machine has a weird setting routine for the Keypad to be told where the Origin is. Press SELECT key and choose “Local” function, and then acknowledge it with ENTER key. Now the screen displays: Position:Origin Current and you can then move the placement of the cutting head by using the direction keys. After the positional adjustment, press SELECT key again to confirm the change of the origin, then lock it in with ENTER key. The MH 871 is much simpler -- Just hit OFFLINE/pause, then the ORIGIN button, use the directional keypad to move the head, then hit OFFLINE/Pause again (returning the cutter online, and it will start cutting at that selected point) Share this post Link to post Share on other sites
dcbevins 340 Posted July 8, 2014 After the positional adjustment, press SELECT key again to confirm the change of the origin, then lock it in with ENTER key. I have a TC1261 and it sounds like it has the same menu system. What slice&dice says is critical. I to scratched my head over this for awhile before I got it correct. After you position the head with the arrows keys, you must have CURRENT selected before you hit ENTER. Skipping that, and the origin will not be set. Share this post Link to post Share on other sites
