Countryside Graphics
CREATE OUTLINE IN COREL X4
Explain a bit more about what you are asking... or upload an example file.
Guest Terry
I think it's the outline tool on left tool bar in Corel, then export to eps. But I'm not sure, I don't use it much but I tried it and it worked in Flexi.
Select your text or object
Effects > Contour from the top menu bar
A window will open on the side and you can select how much offset you want.  You also need to select the direction that you want the contour to go.  Inside or outside or center.  I usually use outside.
After you get it looking the way you want:
Select the the contoured group
then Actions > Break Contour Group Apart from the top menu
You will now have 2 separate objects that you can color and trim or whatever you want to do with them.
