cinnamon457 0 Posted June 6, 2014 I am trying to sublimate dogs tags using a corel draw x7 template from coastal business....I powercliped the pics into the template...everything is lined up perfectly,.....even print preview came out perfect...however, when i send the image to the printer, my pictures appear to have shifted in the template...must be a printing setting i guess...any help would be greatly appreciated.... Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted June 6, 2014 Are you using the MDF jig they sell? it makes it easier also using the full bleed is better than trying to get it to work with the safe area. Share this post Link to post Share on other sites
cinnamon457 0 Posted June 7, 2014 i tried the full bleed...same problem...i dont understand y when i crop the picture it doesnt print what i have left from the crop Share this post Link to post Share on other sites
KYSIGN 233 Posted June 7, 2014 Have you tried the convert to bitmap option? Share this post Link to post Share on other sites
cinnamon457 0 Posted June 7, 2014 no...what do i convert...the entire file..including templates with powerclip photos??....or do i convert template b4 powerclipping photos?? Share this post Link to post Share on other sites
KYSIGN 233 Posted June 7, 2014 Select your power clipped images and either turn off outline or make it white. Then convert each to a bitmap. It will crop the image. Be sure you save it as a new file though. I use it sometimes for print and cut because it makes the file size much smaller. Be sure to adjust the dpi and color settings if needed. Share this post Link to post Share on other sites
