TorbenC 4 Posted June 2, 2014 HiI just got my first Vinyl Cutter, a cheap Copam CP-2500 (To start with)I Just played around with contour cutting, but I can't position the blade through the SignCut software - Nothing happens on the cutter, when using the arrows.Does anyone have a clue why?Regarding this video, and read other places, you can contour cut with almost any cutter: Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 2, 2014 The Video is using Flexistarter with contour cutting. Contour cutting is in the Flexistarter software program. Not Signcut software like you stated The Copam has no way of contour cutting, no laser, nothing. You would need to purchase Flexistarter,10 which can be purchased for under $130 on the big auction site. Flexistarter 10 records from the blade in the middle of each registration mark. And your cutter is not a cheap cutter, it is more to the top of the line of professional stepper cutters. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 2, 2014 copam was my first good cutter - before going servo. very respectable for the price Share this post Link to post Share on other sites
TorbenC 4 Posted June 2, 2014 I have not been able to find a Flexistarter Trial - Would like to test the software 100% through, before buying another one Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 2, 2014 SignCut is good software. Your limitation is your cutter as far as the contour cutting goes. You can get close by manually setting it up but you will never get a real close cut. If you are trying out SignCut then call their tech line and see if they can talk you through the manual setup. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 2, 2014 I have not been able to find a Flexistarter Trial - Would like to test the software 100% through, before buying another one There is not any trial version of Flexistarter 10.. Share this post Link to post Share on other sites
TorbenC 4 Posted June 3, 2014 SignCut is good software. Your limitation is your cutter as far as the contour cutting goes. You can get close by manually setting it up but you will never get a real close cut. If you are trying out SignCut then call their tech line and see if they can talk you through the manual setup. Im aware of that My problem is, that I can't move the blade through the software, to set the points. Don't know if it's a cutter problem, or software problem? Share this post Link to post Share on other sites
TorbenC 4 Posted June 3, 2014 There is not any trial version of Flexistarter 10.. Great.. or something Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 3, 2014 I think you set the points with the machine controls. Share this post Link to post Share on other sites
TorbenC 4 Posted June 3, 2014 I think you set the points with the machine controls. I tried to do that, but when I started cutting, the cutter went back to it's original starting point. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 3, 2014 Like I said I think I would contact SignCut support, they are totally awesome and will get you dialed in if it's possible with your cutter and their software. Share this post Link to post Share on other sites
TorbenC 4 Posted June 4, 2014 I will try that Thank you! But I can feel that I will buy a much better cutter soon, maybe a printer/cutter.. This was just a hobby-thing to help out some friends, but the demand for stickers, posters, banners etc., are extreme! The established companies in the area, charge some insanly prices, when you look at cost-prices and labours. $2800 for covering a trailer (2x5 sq. meters) with some simple logo and script. Share this post Link to post Share on other sites
PixelPusher 46 Posted December 3, 2016 Though this thread is old, I did find a kind of a work-around video for contour cutting using a Copam and Signblazer Elements (I can see the cutter he's using is indeed a CP-2500). It's a multi-step process unfortunately but does seem to yield good results. I warn ya, there is music throughout so watch muted for volume. Share this post Link to post Share on other sites
