MillsRacing77 3 Posted May 29, 2014 My test cuts are not right.. The diamond inside of the box is not even a diamond looks terrible.. My Cutter does not finish at the other end of a letter does not finish the cut i should say..i have to finish the cut with my xacto.. Im getting frustrated and Need Answers.. THANKS!! Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 29, 2014 are all the rollers on the carriage on the track? sometimes the rollers get knocked off in shipping Share this post Link to post Share on other sites
MillsRacing77 3 Posted May 29, 2014 yes they are I have had this thing about a year now... but never has done this.... Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 29, 2014 Remove the blade cartridge & check your blade as it sits into the bearing hole to make sure it's not fouled with vinyl debris and is spinning freely. Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted May 29, 2014 all my 4 years experience with MH Cutters Your cutter came with a Allen wrench.. tighten these with the allan wrench on your rollers.. that fixed my problem when i first got my cutter! hope this helps! Share this post Link to post Share on other sites
MillsRacing77 3 Posted May 29, 2014 Fixed it! Took the Front Cover off and the bolt had come loose... And th enut was stuck to the new Magnet... Thanks 3 Share this post Link to post Share on other sites
