greenkoi 0 Posted May 7, 2014 I can't explain why this is happening. The lines look fine in Illustrator CS6 and CC, but when I either send to SignCut or open EPS in SignCut the cut is inverted. Other files I've cut are in the correct orientation without any setting changes in SignCut. Also, I can't figure out why the P is getting screwed up. Any help / insights would be most appreciated. Thanks ! NewDog11inch.eps Share this post Link to post Share on other sites
Moody Blue 505 Posted May 7, 2014 Looks great to me...I checked the outlines in illustrator and it looks good. Are you using the sign cut plug in through illustrator? If not try saving at the lowest quality .eps (eps 3) and see if that helps. Share this post Link to post Share on other sites
skarekrow 1,842 Posted May 7, 2014 It's been my experience that SignCut prefers svg format files. Mine acts kinda screwy with eps sometimes. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted May 7, 2014 I save to illustrator 8. they work great without having to change your file type to svg or eps. Share this post Link to post Share on other sites
