greenkoi
MH871 / SignCut / Illustrator /
I can't explain why this is happening.  The lines look fine in Illustrator CS6 and CC, but when I either send to SignCut or open EPS in SignCut the cut is inverted.
Other files I've cut are in the correct orientation without any setting changes in SignCut.
Also, I can't figure out why the P is getting screwed up.  10337745_472044646260816_937674945576765
Any help / insights would be most appreciated.
Thanks !
NewDog11inch.eps
Looks great to me...I checked the outlines in illustrator and it looks good.  Are you using the sign cut plug in through illustrator?  If not try saving at the lowest quality .eps (eps 3) and see if that helps.
It's been my experience that SignCut prefers svg format files.
Mine acts kinda screwy with eps sometimes.
