zmajzemun
MH1351 wont start cutting
My MH1351 Refine cutter wont start cutting. Using it at Windows 7 and corel x5, usb connection, till yesterday everything was ok since the beggining. It recognized by WIndows, as soon as command sent it wont start cut and printer pannel says ''error printing''. Conncetion changed on COM/LPT as well but still wont start. I reinstalled drivers, tried to start it on Windows XP and nothing happened, same simptoms.Cutter reacts on commands from its control panel like everything is ok.
Need help about his problem, anyone had similar problem?
I may be wrong but if you are using a USB connection it should be listed as port plus number. Mine list it as reading on port 21. It sounds like you have the wrong port selected in your cutter set up screen. Like I said I may be wrong but thar what it sounds like to me.
Butch
@ Butch
tried to change differents port,its listed on 5 and work normally, same simptoms on other ports as well.
tried to change cables, old ones, new ones but nothing.
FTDI drivers installed as well. Found a link on some other topic and installed but nothing changed, same simptoms after installation.
