Trevinous 1 Posted May 3, 2014 Hello! We just got the SC cutter, unboxed and setup. Removed the protective tape from the inside, installed the blade then turned the power button on. The carriage slides along to the right and hits the right far side. This is where the problem starts. It doesnt stop, It just keeps trying to go right into the side. And it makes a horrible noise as it cant go any farther. You can push the reset button down and it stops for a second and then tries to run into the side again and starts its terrible noise up again. We have tried turning it off and on, taking the blade out. We have tried manually moving to the left a little and it just runs back to the right and freaks out. Thank you for your support. Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 3, 2014 OK, you'll have to perform some minor surgery --- take a phillips screwdriver and remove the top cover (first take off the 2 end caps, each one is held on with two screws). There's a limiter switch / contact switch which you'll have to jiggle and make sure it is in the proper position. Share this post Link to post Share on other sites
derkdaigler 7 Posted May 3, 2014 Mine hits the wall pretty hard too. Was wondering if that was normal Share this post Link to post Share on other sites
Trevinous 1 Posted May 3, 2014 Hey guys! Awesome! We took the top off and bent the little piece of metal down so it hit the contact switch. Everything works awesome now! Thank you for your help! 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 3, 2014 Like I said, a little bit of minor surgery, and you're good to go. Yeah, I sometimes come up with the right answers, so here's a gold star for me 3 Share this post Link to post Share on other sites
zombrolio 1 Posted June 6, 2019 2019 and this thread is still helping people like me. I was ready to take a sledgehammer to this thing.. is ok now cheers 1 Share this post Link to post Share on other sites
Treal 0 Posted March 14, 2020 Hello where is this limiter switch located Share this post Link to post Share on other sites
Treal 0 Posted March 14, 2020 On 6/6/2019 at 6:18 AM, zombrolio said: 2019 and this thread is still helping people like me. I was ready to take a sledgehammer to this thing.. is ok now cheers Hi can you share where you found the stopping thing I’m still having issues with it hitting the side Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 14, 2020 5 minutes ago, Treal said: Hi can you share where you found the stopping thing I’m still having issues with it hitting the side Scroll down page to step 2 https://www.uscutter.com/static/PDFs/carriage_off_track.pdf 1 Share this post Link to post Share on other sites
Treal 0 Posted March 14, 2020 On 6/6/2019 at 6:18 AM, zombrolio said: 2019 and this thread is still helping people like me. I was ready to take a sledgehammer to this thing.. is ok now cheers Hi can you share where you found the stopping thing I’m still having issues with it hitting the side 14 minutes ago, MZ SKEETER said: Scroll down page to step 2 https://www.uscutter.com/static/PDFs/carriage_off_track.pdf Hey I am definitely missing those two parts on both sides? Don’t see them. I also hit the reset button now it doesn’t do anything anymore it’s a blank screen Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 14, 2020 1 minute ago, Treal said: Hi can you share where you found the stopping thing I’m still having issues with it hitting the side Hey I am definitely missing those two parts on both sides? Don’t see them. I also hit the reset button now it doesn’t do anything anymore it’s a blank screen I can only show you what I found on UScutter site. I don't own that cutter. Maybe someone who has one, will drop in. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 14, 2020 2 minutes ago, Treal said: Ahhh ok Here is another answer from USCutter site https://support.uscutter.com/hc/en-us/articles/360037908791-Carriage-will-not-stop-moving-to-the-right-on-the-SC2- Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 14, 2020 Your posting to a thread about the SC vinyl cutter. Do you have an SC or an SC2 vinyl cutter? 1 Share this post Link to post Share on other sites
Treal 0 Posted March 14, 2020 36 minutes ago, MZ SKEETER said: Your posting to a thread about the SC vinyl cutter. Do you have an SC or an SC2 vinyl cutter? Sc2 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 14, 2020 1 minute ago, Treal said: Sc2 This is for SC2 https://support.uscutter.com/hc/en-us/articles/360037908791-Carriage-will-not-stop-moving-to-the-right-on-the-SC2- 1 Share this post Link to post Share on other sites
