daynj
CTO630 "working laser" on LCD when sending commands from PC
Hi
I have just purchased a PCUT CTO630.
All of the operations are working on the control pad in "offline mode" but as soon as I set it to "online" and try to send it a command from the PC, the cutter LCD just displays "working laser" and nothing happens.
How can I fix this problem?
The software I have tried is SignCut Pro and SignBlazer.
I have set up the cutter preferences how the tutorials have said to yet I still receive this problem and I cannot find a solution to it anywhere.
I have tried it with both USB and serial connections.
Thanks.
Hi, i see that you have posted regarding a different issue with this cutter since posting about the "working laser" issue so I assume you have managed to sort this, could you please post what the issue was, i'm having the same issue.
Thanks,
Adam.
I think that baud rate was wrong I set to 38400 and it works
But I had the same issue and i was beginning my head against a brick wall and saw something somewhere regards the baud rate and it worked
Although I don't have much luck using the cutter with signcut it always stops halfway through the job
I have had more luck with signblazer elements which seems to work fine although the program itself is rather ugly and hard to navigate and get used to
I wanted to use signcut because of the plugin for illustrator you can just export the design and that's it done with
Signblazers a mess in that aspect
