gmddecals 0 Posted April 22, 2014 Hi! I am having trouble with cutting software for the SC series of US Cutter plotters. Currently I have been using SCALpro as that came with my machine. I have also tried- Flexicut pro: it seems fairly complicated and will not import my scal designs properly at all, no SC model drivers Make The Cut: no drivers seem to be compatible with the SC model Signcut Pro- looked like a complicated mess. On the other hand, I have learned cutting by using a Silhouette cameo with the silhouette software, which is very easy for me to navigate. My question is this: What software can I use that is USER FRIENDLY and also has a driver for my SC model? If it can read my SCAL or .studio files that would be great so I wont have to re-do all of my files. I have tried exporting/importing as svg files and they aren't copying the cut files properly. :/ I am beginning to feel like an idiot, so thought I would check and see if anyone could help. Thanks so much! Share this post Link to post Share on other sites
mb20music 760 Posted April 22, 2014 SignBlazer is very user friendly. I believe you will need to select LiYu HF-1202 drivers for the SC. http://support.uscutter.com/index.php?/Knowledgebase/Article/GetAttachment/190/24198 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2014 The SC cutter is a rebranded Liyu cutter. So you will need to find Liyu in Flexisign. Uscutter also has a Flexi driver pack in the support section of UScutter. for all of the value cutters.. 1 Share this post Link to post Share on other sites
gmddecals 0 Posted April 22, 2014 Thank you very helpful! I think I will try the Flexisign as it gets such good reviews. I am converting the files to .plt files in SCAL and then opening in Flexicut. It seems to be retaining proportions correctly, however I am not in the office so I cannot test the cut. Im crossing my fingers that this will go smoothly tomorrow. Thank you so much! Share this post Link to post Share on other sites
mb20music 760 Posted April 22, 2014 I just discovered if you download SignBlazer from that link I posted, it will also download USCutter drivers. Click on the "USCutter Drivers" icon and you then select the cutter model you have in the dropdown menu. Then click install. 1 Share this post Link to post Share on other sites
