robertoo31
Mh721-mk2 problem
I I just bougth this plotter I did install all by the instruccions but the cutting cartrige doesn't move in x way all seems ok I did move it with my hand and is not lose or hang move easyli but ehen I try to move by test or by pushing the positioning button doesn't work.
Any one can tell me how to fix this?? thanks
sounds like a call to support Monday- does it make a sound like the motor is moving in that direction?
if you are adventurous you might want to pop the bottom of the cutter off and make sure all the wires are still connected to the Mainboard - it has happened before where a wire has came loose in the 15000 miles since being built
Hi, welcome to our little Forum.
There is a red button on the right side, that's the "cutoff" limiter switch (it stops the carriage from moving once it touches the button).
Check to see it's free and not stuck.
doesn't that normally cause the black boxes in the screen with no function - not just stopping the x axis movement?
