joefraga 3 Posted April 19, 2014 Hello, I am new here. I searched and searched this forum to find an answer to my question but could not. Is there a way that i can have my MH 721 or Titan 2 completly cut my vinyl after I am done with my cut? I have seen videos where after the cutter is done with a decal it advances an inch or so and the blade then completly cuts the vinyl. Thank you for taking the time to read my question. Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted April 19, 2014 I do not think a MH Can do that.. Can you show the youtube video you are talking about? Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted April 19, 2014 The graphtec fc series...at least the newer ones will cut off your vinyl 1 Share this post Link to post Share on other sites
skarekrow 1,842 Posted April 19, 2014 Would be kinda hard on blades cutting through the backing, especially that mylar on the back of HTV, wouldn't it? Or is there a seperate blade for this action? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 19, 2014 Would be kinda hard on blades cutting through the backing, especially that mylar on the back of HTV, wouldn't it?Or is there a seperate blade for this action? It uses a different , much larger blade. It also has it on the FC7000. The carriage head is totally different, on the FC models, than the ones on the CE models. There is a groove across the cutter width, that this blade runs down thru, so the blade is not in contact with the cutting strip. http://www.uscutter.com/Graphtec-Cross-Cutter-Blade-Standard 5 Share this post Link to post Share on other sites
skarekrow 1,842 Posted April 19, 2014 Definately a handy function! Share this post Link to post Share on other sites
