LKline 4 Posted April 18, 2014 Starting to get frustrating. Anything over 4 inches I have to stand here and constantly raise it a little over the ruler so it doesn't ruin a straight line of text. Gets caught on this ruler and snags the vinyl. Even bent the end of the vinyl but there's always one small section that catches no matter what. Share this post Link to post Share on other sites
pshawny 410 Posted April 18, 2014 My old Laserpoint use to do that. Put a strip of vinyl or tape across it. I think that notch is there to mount something that allows you to run flat-stock material through it. 5 Share this post Link to post Share on other sites
darcshadow 1,626 Posted April 18, 2014 Same here, put some scotch tape on it and haven't had a problem since. 1 Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted April 18, 2014 You can also just bend up that edge a touch. But the tape idea works great. 1 Share this post Link to post Share on other sites
LKline 4 Posted April 18, 2014 Thanks fellas, did the tape trick. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted April 19, 2014 P cut does that I belive it is a cut off grove or at least that is what I use it for. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 19, 2014 the ruler itself causes that and most put tape over it but the extra groves area actually for these http://www.uscutter.com/Flatbed-Tray-for-Creation-PCut-Set-of-2 Share this post Link to post Share on other sites
Go-C Graphics 856 Posted April 19, 2014 Yep. I used packing tape. Share this post Link to post Share on other sites
