tyamp 0 Posted April 16, 2014 can silhouette design software be used with a cutter that is not a cameo? Im asking because i have a lot of stuff ready to cut (made with silhouette) and my new software(scal3) is not as easy for me to use(yet). Share this post Link to post Share on other sites
mb20music 760 Posted April 16, 2014 I don't believe so. You might try SignBlazer Elements software, I think it is more user friendly than SCALP. 1 Share this post Link to post Share on other sites
Jay2703 704 Posted April 16, 2014 Can the silhouette software export an .svg file? You could export it then cut it with SCALP. 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted April 16, 2014 Download and install SBE -- it handles *.dxf;*.eps;*.ai;*.bmp;*.tif;*.gif;*.pcx;*.tga;*.jpg;*.pcd;*.pct;*.psd;*.cmx;*.ps; (NOT .svg) http://support.uscutter.com/index.php?/Knowledgebase/Article/GetAttachment/190/24198 I found this posting from another recent thread --- Graphtec Studio, which is basically the same thing, can't export. I was googling a while back and found that you can install a PDF writing program and instead of cutting or saving your file, click print and select the PDF writer, which will make it create a PDF with your image inside. You can then open the PDF with inkscape and export the image as eps. 1 Share this post Link to post Share on other sites
tyamp 0 Posted April 17, 2014 Download and install SBE -- it handles *.dxf;*.eps;*.ai;*.bmp;*.tif;*.gif;*.pcx;*.tga;*.jpg;*.pcd;*.pct;*.psd;*.cmx;*.ps; (NOT .svg) http://support.uscutter.com/index.php?/Knowledgebase/Article/GetAttachment/190/24198 I found this posting from another recent thread --- Graphtec Studio, which is basically the same thing, can't export. I was googling a while back and found that you can install a PDF writing program and instead of cutting or saving your file, click print and select the PDF writer, which will make it create a PDF with your image inside. You can then open the PDF with inkscape and export the image as ei dont see option for pdf writer Download and install SBE -- it handles *.dxf;*.eps;*.ai;*.bmp;*.tif;*.gif;*.pcx;*.tga;*.jpg;*.pcd;*.pct;*.psd;*.cmx;*.ps; (NOT .svg) http://support.uscutter.com/index.php?/Knowledgebase/Article/GetAttachment/190/24198 I found this posting from another recent thread --- Graphtec Studio, which is basically the same thing, can't export. I was googling a while back and found that you can install a PDF writing program and instead of cutting or saving your file, click print and select the PDF writer, which will make it create a PDF with your image inside. You can then open the PDF with inkscape and export the image as eps. i dont see option for pdf writer found it but inkscape??? Share this post Link to post Share on other sites
tyamp 0 Posted April 19, 2014 bullzip is what u needs.....Thanks guys Share this post Link to post Share on other sites
