Racer10 0 Posted March 28, 2008 I have gone throuth the program help and the manual. I have looked at a few pages and haven't seen anybody talk about this recently. I am getting the above error and have not been able to fix. I have restarted the computer and my refine a few times. The computer is plugged in via USB. Test cut works fine (not surprising). What else can I check? Thanks!! Share this post Link to post Share on other sites
FatDad 2 Posted June 15, 2008 this is the same problem i am now having Share this post Link to post Share on other sites
BannerJohn 1,324 Posted June 15, 2008 what are your settings? baud rate,port? This error means that the vcomputer is not communicating with the cutter. It is usually a port problem. Share this post Link to post Share on other sites
Knobhill 0 Posted June 16, 2008 Make sure you set the com port on your computer to com4 or lower for the USB serial port. Or try using the serial or parallel connections if you can. I've not seen any use lately for the serial port on most computers so I recommend using it instead. Here's some good info http://forum.uscutter.com/index.php/topic,1602.0.html Share this post Link to post Share on other sites
