pshawny 410 Posted April 10, 2014 So far I've only print/cut a couple of designs. I could use some advice on the proper way to do it instead of my improvised way of doing things. I'm printing on a 24" printer, then cutting with a 24" Graphtec. My first test was with the Coors Light logo. I ended up with this as my shape to cut. I don't know how to add bleeds, so there were a couple of spots where the cutter was off by a hair that showed white around the design. What is the proper way to get cut lines around a graphic? How do you add a bleed around graphics? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 10, 2014 Is this what your looking for? Many videos on youtube.com Share this post Link to post Share on other sites
pshawny 410 Posted April 10, 2014 I already have that part figured out. I was wondering more about adding cut lines & bleeds. This video helped me to understand how to create cut lines easier and faster than I was doing it. What about adding a slight bleed in case the cut isn't exactly on the cut line? Share this post Link to post Share on other sites
mark-s 1,126 Posted April 10, 2014 Take read through this. mark-s AI_CS_-_How_To_Contour_Cut_(03.08.2005).pdf Share this post Link to post Share on other sites
Wildgoose 4,200 Posted April 10, 2014 Bleed is on the print side of things. In CS2 I think you have to set bleed in the print dialog box. Once you push print in the file menu it will open the print dialog box and on the left side is a box with a bunch of options including marks and bleed. Max bleed is 72pt. Share this post Link to post Share on other sites
Moody Blue 505 Posted April 10, 2014 Easiest way is to take the background image...let's call it the black blob and just add a stroke to it. You can increase the size of the stroke until it is larger than the top layer. To cut you will need to "Object>expand" and then weld the two parts together in turn making the background image appear larger without skewing the shape or resizing causing worlds of alignment issues. Hope this is what you are talking about. 1 Share this post Link to post Share on other sites
pshawny 410 Posted April 11, 2014 Here is what I finally decided on for a cut shape. 1 Share this post Link to post Share on other sites
patrickjohnson 2 Posted June 16, 2014 The use of Silhouette Cameo. Share this post Link to post Share on other sites
