iamandy 20 Posted April 5, 2014 I'm trying to get better at creating double layer decals so I'm trying to cut something for my daughter's nursery. However, when I go to cut, some of the cuts (mouth, eyes) are cutting into the background color and not the foreground color. Can someone point me in a better direction? I know I'm doing something wrong, but I can't figure out what. Thanks in advance. ******Copyrighted image deleted by moderator********** Share this post Link to post Share on other sites
bikemike 711 Posted April 5, 2014 Try this one. Yours was not 2 colors. White don't count. Share this post Link to post Share on other sites
bikemike 711 Posted April 5, 2014 Oops, missed the file ******Copyrighted image deleted by moderator********** Share this post Link to post Share on other sites
iamandy 20 Posted April 5, 2014 When I try to cut that, It only has one color. I'm looking to cut so the black is one sheet and the "White" is layered on top with the black showing through. Is that possible? Share this post Link to post Share on other sites
bikemike 711 Posted April 5, 2014 Ya, use the file I posted. First just cut the black, then cut the purple color, then layer the purple on top of the black. Make sure you cut by color. Share this post Link to post Share on other sites
iamandy 20 Posted April 5, 2014 When I first loaded the file, it only showed black. There was a rgb/cmyk issue. Share this post Link to post Share on other sites
iamandy 20 Posted April 5, 2014 These are the screenshots of what the cutter sees when I select each color. Share this post Link to post Share on other sites
bikemike 711 Posted April 5, 2014 That's weird. Should look like this. Share this post Link to post Share on other sites
iamandy 20 Posted April 5, 2014 Thats what I thought. Share this post Link to post Share on other sites
bikemike 711 Posted April 5, 2014 That signblazer? Need a signblazer person to join in. I did that in corel draw and cutting master. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 5, 2014 sorry guys and gals had to remove the copyrighted material from uscutters server Share this post Link to post Share on other sites
iamandy 20 Posted April 5, 2014 Sorry about that. Regardless, This image is doing the same thing. Am I doing something wrong when vectoring the images? images.jpeg.eps Share this post Link to post Share on other sites
bikemike 711 Posted April 5, 2014 That one has 3 objects in it. ungroup and delete the blank square and it should work. Share this post Link to post Share on other sites
iamandy 20 Posted April 5, 2014 What program do you use for plotting? When SignCut Pro opens it, it's very weird acting. Could it be a ScP issue? Share this post Link to post Share on other sites
bikemike 711 Posted April 5, 2014 I am using cutting master. It is only for a Graphtec. We need a sign cut person to join in. Share this post Link to post Share on other sites
skarekrow 1,842 Posted April 5, 2014 I opened the file above in SignCut... its screwy. Here it is in 2 color. (provided the mod doesn't remove it) SmileyFace_2color.eps SmileyFace_2color.svg Share this post Link to post Share on other sites
skarekrow 1,842 Posted April 5, 2014 Yes, evidently you are doing something wrong when vectoring the images. Share this post Link to post Share on other sites
iamandy 20 Posted April 5, 2014 Yes, evidently you are doing something wrong when vectoring the images. I use image trace in Illustrator. Is there a preferred method? Share this post Link to post Share on other sites
bikemike 711 Posted April 5, 2014 Ya, like skarekrow's. Except I would have done a black background and cut out the grey part for the eyes and mouth. Same thing, different approach. Share this post Link to post Share on other sites
bikemike 711 Posted April 5, 2014 Why are you tracing a vector image? Load the image, and send to cutter. Share this post Link to post Share on other sites
skarekrow 1,842 Posted April 5, 2014 I use image trace in Illustrator. Is there a preferred method? Many folks have complained about Illustrator's Trace engine... I'm not crazy about it either. I like and use Inkscape when tracing. It's free as well. Also, there are a few small bugs in the 0.48 version. I have stayed with 0.47 Share this post Link to post Share on other sites
iamandy 20 Posted April 5, 2014 I tried Inkscape, but it won't load correctly on my Mac. I guess I'll try it again. Share this post Link to post Share on other sites
skarekrow 1,842 Posted April 5, 2014 I tried Inkscape, but it won't load correctly on my Mac. I guess I'll try it again. Curious... were you trying to load the Mac version of Inkscape or the Windows version with an enabler like "WineBottler"? Share this post Link to post Share on other sites
iamandy 20 Posted April 5, 2014 I'm using the mac version with xquartz and I can't seem to get inkscape to open Share this post Link to post Share on other sites
