hopkinsrj
Node lines missing
Hopefully someone can help! I have been using Signblazer for a few years new and the other day I opened it up and used poly lines to outline an image, when I went to move the modes I found that the lines that used to connect the nodes were gone,  The nodes are there but the lines are gone and I need the lines.  Anyone have any idea how to get the lines back?
When you are in Node Edit mode if you click on the color bar at the bottom of the screen it allows you to change the color of the nodes or the lines:
Go into Node Edit mode again.
Select the color you want your lines to be from the color bar at the bottom of the screen
Click the Line Color radio button from the box that pops up
Click OK
Your lines will be that color until accidently you change them again.
