ShowMeCleaning 53 Posted March 1, 2014 Wildgoose thanks for replay, yes I'm using easy weed. I'll check out the infra-red thermometer gun. Is there a rule of thumb of the thickness your pressing onto? Share this post Link to post Share on other sites
Wildgoose 4,200 Posted March 1, 2014 Doesn't make much difference as long as you can get a good even pressure across the whole area. Some of the presses have a max thickness that they can deal with but for garments you won't have any problems. Share this post Link to post Share on other sites
ShowMeCleaning 53 Posted March 2, 2014 Thank You Wildgoose, for your reply. I'm sure I'll have more questions. Wet between the ears on this vinly work. 1 Share this post Link to post Share on other sites
cjs 14 Posted March 6, 2014 I had to do the same thing! lol Share this post Link to post Share on other sites
cjs 14 Posted March 6, 2014 Nothing more annoying that not flipping and noticing when its too late... did it many times at first, but the post it note on the machine fixed that! Share this post Link to post Share on other sites
jaybyrd 3,770 Posted March 7, 2014 Wait until you're in a rush and don't notice it until you open the press . Share this post Link to post Share on other sites
TT57 135 Posted April 4, 2014 don't forget when you use the carrier sheet - I use the cricut one since I still use my Expression ( big cricut)- it is thicker than running thru without so I had to adjust my blade depth and pressure. Share this post Link to post Share on other sites
