2001kx 0 Posted February 12, 2014 lets say i have 2 decals to cut and im going to cut 1 at a time. i cut the first one and when im done i have to lift the pinch roller to rest to origin to cut again. is this the only way to do it? i use corel draw to cut Share this post Link to post Share on other sites
arty-rc 719 Posted February 12, 2014 Just push the origin button It will start cutting from that position. Make sure you have enough vinyl to make it. Share this post Link to post Share on other sites
Trumpy 5 Posted February 12, 2014 Push the back arrow to retract the vinyl so the edge of the vinyl is even with the front of the cutting strip. Then push origin. Share this post Link to post Share on other sites
skarekrow 1,842 Posted May 10, 2014 Yes, if you have the machine set up for LL (left lower) as the origin point you only need to use the arrow keys on the machine to set the blade to the LL and push the origin point button. Share this post Link to post Share on other sites
