JJennings 4 Posted February 10, 2014 Hello Everyone,,, I need some Help again... I am using the Corel Draw Graphic Suite 12 to design an image./ Monograms. and it looks fine when I finish,,, Then I get ready and Export it to my Cutter software Sure Cuts A Lot 2 and I have tried also in my SignGo FD and it does the same thing.. I go to File,, Import and pull the Image / Monogram up ,, but it Never shows up on my matt for cutting I have tried several times an it just is not there....... What am I doing wrong,,, Is it just a setting of size or what..... Need your help Please,,, Thanks Judy Share this post Link to post Share on other sites
knucklehead 530 Posted February 10, 2014 Try the launcher button. Top tool bar, looks like a little rocket ship, should drop down a menu with your cutting software, then just click and cut. Share this post Link to post Share on other sites
OWJones 1,981 Posted February 10, 2014 What file format are you exporting it to from within CorelDraw? If you can attach a copy of the file you exported, we can take a look at it and try to diagnose your issue. Share this post Link to post Share on other sites
JJennings 4 Posted February 10, 2014 OW Jones, Here is the information I see on the screen,, when I go to Export the image... File Name: Hunter Baseball Save as Type : AI Adobe Illustrator Sort Type : Default Then the link is : C:\Documents ans=d settings\JUDY\MyDocuments\HunterBaseball.ai then I hit the Export at bottom of screen and go to SignGo site and do File Import and find the Image of Hunter Baseball and Open,,, but nothing shows up on the matt for me to cut... Thanks for any help ..Have a Blessed Day Share this post Link to post Share on other sites
JJennings 4 Posted February 10, 2014 Sorry OW Jones.. Typing error where it is Documents and Settings...I dont know what happened Thanks Share this post Link to post Share on other sites
lueman 19 Posted February 13, 2014 I had similar problems I gave up & send everything from Corel now. I used to export to Inkscape then save as an SVG, then import. But the vector files wouldn't always decode correctly in SCAL. It was just not worth the hassle. Share this post Link to post Share on other sites
lueman 19 Posted February 13, 2014 I rarely export to AI If I need an Ai I convert to PDF 8.0 or lower Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted February 21, 2014 I usually export as PNG and have no issues. Share this post Link to post Share on other sites
patrickjohnson 2 Posted May 23, 2014 It is better to export image in PNG format so that u can open in both softwares Share this post Link to post Share on other sites
