JJennings
Transferring Images from Corel Draw
Hello Everyone,,, I need some Help again... I am using the Corel Draw Graphic Suite 12 to design an image./ Monograms. and it looks fine  when I finish,,, Then I get ready and Export it to my Cutter software  Sure Cuts A Lot 2 and I have tried also in my SignGo FD and it does the same thing.. I go to File,, Import and pull the Image / Monogram up ,, but it Never shows up on my matt for cutting I have tried several times an it just is not there....... What am I doing wrong,,, Is it just a setting of size or what..... Need your help Please,,, Thanks Judy
Try the launcher button. Top tool bar, looks like a little rocket ship, should drop down a menu with your cutting software, then just click and cut.
What file format are you exporting it to from within CorelDraw?
If you can attach a copy of the file you exported, we can take a look at it and try to diagnose your issue.
OW Jones, Here is the information I see on the screen,, when I go to Export the image...
File Name:   Hunter Baseball
Save as Type :  AI  Adobe Illustrator
Sort Type :  Default
Then the link is :  C:\Documents ans=d settings\JUDY\MyDocuments\HunterBaseball.ai
then I hit the Export at bottom of screen and go to SignGo site and do File  Import and find the Image of Hunter Baseball and Open,,, but nothing shows up on the matt for me to cut...
Thanks for any help ..Have a Blessed Day
I had similar problems I gave up & send everything from Corel now. I used to export to Inkscape then save as an SVG, then import. But the vector files wouldn't always decode correctly in SCAL. It was just not worth the hassle.
