Seren Brown 0 Posted February 5, 2014 Hi All, Im needing some help with the followingIm using CorelDraw X4 as my main designing program. When im ready to cut the graphics I export it in to Artcut 2009 as a PLT-HPGL Plotter file. Since updating to windows 8 when opening the file in artcut with what are smooth curves turn into small lines to make the shape or text.Has anyone had this error? If so please could you tell me the way to fix this. Thank you Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 5, 2014 Sounds like it's getting converted to a dxf type file. Check your export settings. dxf files are for plasma cutters and use splines instead of brazier curves. Share this post Link to post Share on other sites
patrickjohnson 2 Posted May 30, 2014 I think it's getting converted to a dxf type file.Check your export settings. dxf files are for plasma cutters and use splines instead of brazier curves. Share this post Link to post Share on other sites
