3barefoot 52 Posted February 5, 2014 Ok I got this huge subway art order.. WELL when cutting the bottom half cut GREAT... The top not so much.. What happend?? I have tried to recut the top part by its self 2 times.. Even put a new blade in on the 3rd time and it still messing up.. Here are all the pics This is what I'm trying to cutThis is the bottom half that came out fine. This is the top part. look mainly at the Y's E's O's W's V's This is a closer look.. the W in slow came out fine. But it didn't in WANT. Some E's came out fine and some didn't. I just don't get it! Please help. Letter size is 1.3" off set is 0.33mm and the speed on the cutter is 100MM and PRS is 34G Share this post Link to post Share on other sites
joker 618 Posted February 5, 2014 What machine are you using? Share this post Link to post Share on other sites
security802 686 Posted February 5, 2014 Is it tracking straight thru your cutter? Feed the whole length thru before cutting and see if it is. Just a thought Share this post Link to post Share on other sites
3barefoot 52 Posted February 5, 2014 US Cutter SCplotter Share this post Link to post Share on other sites
3barefoot 52 Posted February 5, 2014 Is it tracking straight thru your cutter? Feed the whole length thru before cutting and see if it is. Just a thought First time no.. The vinyl didn't go straight, I don't know how it got off track. But now YES it goes straight. Share this post Link to post Share on other sites
BCOJdecals 39 Posted February 5, 2014 I have no solution for your cutting problem, but during a quick look-over, I noticed that line 13's "then" should be "than." -- grammar And lines 8 & 10 "your never forget." And line 21'a "then" should be "than." Not being an a-hole...just tryin' to help ya out. Share this post Link to post Share on other sites
joker 618 Posted February 5, 2014 I usually power that same machine down before every cut. I have not cut anything that big yet. But i have my blade where you can barely see the tip. My offset is set at .35 and i run my speed at 200 with 23g pressure. Also use a 60 degree blade. Also do you have a keyspan connected or straight usb cable? Share this post Link to post Share on other sites
3barefoot 52 Posted February 5, 2014 I have no solution for your cutting problem, but during a quick look-over, I noticed that line 13's "then" should be "than." -- grammar And lines 8 & 10 "your never forget." And line 21'a "then" should be "than." Not being an a-hole...just tryin' to help ya out. Those had already been corrected when I cut the first time.. just didn't save cause I went back and deleted the bottom half to recut. 1 Share this post Link to post Share on other sites
security802 686 Posted February 5, 2014 go to view and click outline only, that puts it in wire frame look. maybe you have something a skew up there?? Just a thought Share this post Link to post Share on other sites
security802 686 Posted February 5, 2014 Those had already been corrected when I cut the first time.. just didn't save cause I went back and deleted the bottom half to recut. Instead of deleting change the color and then use the cut by color option saves time and headache Share this post Link to post Share on other sites
3barefoot 52 Posted February 5, 2014 The cutter has been powered off hints I have cut this 3 times.. The size is 24x36" the blades I have are 0.25mm Share this post Link to post Share on other sites
3barefoot 52 Posted February 5, 2014 Instead of deleting change the color and then use the cut by color option saves time and headache Thanks for the short cut! Share this post Link to post Share on other sites
security802 686 Posted February 5, 2014 are you cutting from origin point or wysiwyg? are you serial or usb? Share this post Link to post Share on other sites
Fatboy 13 Posted February 5, 2014 Sometimes mine would do weird cuts like that towards the end of my cutting session thou, What helped me out a little was cleaning the pinch rollers and the cutting strip. That might help a little bit. Share this post Link to post Share on other sites
BrianMaruska 12 Posted February 5, 2014 My SC cutter does that sometimes when I am hooked up with a USB. You should be okay with just making that into two separate cuts or even more as long as you're comfortable with spacing something yourself. Best workaround I have been able to come up with when in a pinch on my cheaper cutter. Share this post Link to post Share on other sites
3barefoot 52 Posted February 5, 2014 So maybe I should change being hooked up with the USB?? Share this post Link to post Share on other sites
joker 618 Posted February 5, 2014 You can buy the keyspan. I run my sc with the usb connected to my laptop. Share this post Link to post Share on other sites
DNA_Vinyl 262 Posted February 5, 2014 I had the same problem. some what. I bought a keyspan and all is good now. I reinstalled all the software when I got the keyspan just to be sure. not everything is perfect. *knock on wood* Share this post Link to post Share on other sites
security802 686 Posted February 5, 2014 So maybe I should change being hooked up with the USB?? Either keyspan or get a serial card of its a desktop and you have a slot Share this post Link to post Share on other sites
jessefisher4 35 Posted February 5, 2014 I have run my cutter with a keyspan since the day I got it. Have yet to have any of these kinds of things happen. Knock on wood! lol Share this post Link to post Share on other sites
3barefoot 52 Posted February 5, 2014 Yeah of all desktop's... OF course mine doesn't have one... and my computer isn't even a year old! GRRRR!! Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 5, 2014 Why don't you post that file and let one of us look it over to rule out a problem with the file before you spend a bunch of time or money or both on the cutter. It is odd that one or two letters here and there are coming off wrong. When the cutter cuts them is it cutting the whole line in order or is it jumping around and cutting some here some there and coming back to the ones that are messed up last? Share this post Link to post Share on other sites
3barefoot 52 Posted February 5, 2014 It jumps around. Doing a test run of changing the color on the screen. The red part is the one that's not cutting like it should... The black cut fine! my wish2.svg Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 5, 2014 I can't see any problems with the file. I would place my bet on a tracking issue. Try breaking the red down into smaller sets to see if it helps. I realize that's going to waste vinyl so maybe try your pen attachment and some butcher paper. It may not show up doing that but you wouldn't be out much trying. I used to run a P-Cut and it would sometimes go a little crooked when doing long strings of text and when it came back for the in-between letters it would mess them up. Usually it was an e or an o or something though so I am still puzzled at the Y and W issues. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 5, 2014 You might try rotating the whole thing and cutting however much will fit on your vinyl. That might tell you something if the same letters are getting messed up. 1 Share this post Link to post Share on other sites
